  3. Joining a line between two points on the output waveform...
  • Views 13043
Joining a line between two points on the output waveform in Cadence Virtuoso calculator tool
Senan
Senan over 4 years ago
I would like to ask if it is possible to create a straight line on the output waveform that joins two selected points from the waveform by using the Cadence calculator tool
Thank you
Best Regards
    ShawnLogan over 4 years ago
    Dear Senan.
    Mr. Andrew Beckett has written a SKILL function that can imported as a custom function in the Calculator that creates a line using the first and last points of its waveform. In you case, if you clip the waveform using the clip() function between the two points that you want to use to define your line, it seems that this function, when applied to the clipped waveform, will accomplish your task.
    His SKILL function, with instructions, is at the Cadence On-line Support site URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009106HUAQ&pageName=ArticleContent
    I hope this helps Senan!
    Shawn
  • Senan
    Senan over 4 years ago in reply to ShawnLogan
    Dear Shawn
    Thank you very much for your reply and your kind help,
    it is perfect solutions
    Best Regards
