  3. 5G signal sources and simulation inside Spectre / Virtu...
  • Replies 11
  • Views 18249
5G signal sources and simulation inside Spectre / Virtuoso
sidm
sidm over 4 years ago
Hello All,
I am using IC618 & Spectre ISR20
do we have signal sources for 5G signal simulations inside Spectre / Virtuoso like there is a LTE source in RFLIB ?
Also does ICADVM20 version offer any advantages over IC618 towards this direction  ?
regards
    Andrew Beckett over 4 years ago in reply to sidm
    Looking through when this was added, I think you need to be using at least SPECTRE18.1 ISR8 and IC6.1.8/ICADVM18.1 ISR6 (so with .500.6 on the end). My guess is you're not meeting one or the other of these.
    There's a bit more about it in this article: What is the CCDF function in the Direct Plot Form after running wireless analysis?
