  3. Virtuoso layout hierarchical copy contains mysterious residue...
  • Replies 7
  • Views 15702
Virtuoso layout hierarchical copy contains mysterious residue from other libraries
chenyanw
chenyanw over 4 years ago
I have never seen such a weird issue with hierarchical copy in Virtuoso. Let me explain.
We have a brand new library and brand new layout cellview (say "Lib_debug/debug_cellview/layout"), inside which there is an instance of Cell_target from our production library Lib_B and nothing else.
Lib_B/Cell_target used to have our real designs in it, but for debugging purpose, I deleted everything (including shapes, nets, instances, constraints and connectivity reference) and then drew only a piece of rectangle so it won't look empty.
Now I want to hierarchically copy it from "Lib_debug/debug_cellview/layout" to "Lib_debug/debug_cellview2/layout". I used the following copy menu. Note that none of Lib_A, Lib_B or Lib_C are in the skip libraries list.
Once I click OK, I get the following window. It is very strange that Lib_A shows up. While we did copy design from Lib_A when Lib_B was initially created, I have removed every instance in Lib_B/Cell_target. So I don't know where they are coming from.
So where does the Virtuoso copy tool find such information and how can I delete it?
I'm using Virtuoso ICADVM20.1
Thanks for any help!
    ShawnLogan over 4 years ago
    Dear chenwanw,
    I believe the data.dm file may have information about cells in a library and other libraries. Please take a look at Andrew's response a number of years ago concerning what the data.dm file contains at the Cadence On-line support site URL:
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/37085/what-is-the-use-of-data-dm-and-constraint-in-each-design-directory
    As you are doing a hierarchical copy, there may be instances within the Lib_debug layout that are subcircuits from Lib_A or Lib-B and hence the "Copy Problems" GUI you included in your posting show cells from Lib_A and Lib_B. If you deleted the cells, maybe you did not update the data.dm file and hence it shows the cells.
    Does this help at all chenyanw?
    Shawn
  • chenyanw
    chenyanw over 4 years ago in reply to ShawnLogan
    Hi Shawn,
    Thanks for your reply. It's been my suspicion with data.dm. I have used ddGetObj to decode and read them (I have data.dm in the library and view level). However, I still can't find any reference to Lib_A. Is there anything in data.dm that can't be read out by ddGetObj...?
    ShawnLogan over 4 years ago in reply to chenyanw
    Dear chenyanw,
    I am sorry, but I do not have the background to provide a useful comment to your question. Perhaps the experts who follow this Forum might have some insight.
    Shawn
    Andrew Beckett over 4 years ago in reply to ShawnLogan
    I don't think it's going to be in the data.dm files. Most likely there's a reference in the layout database to the cellView.
    Two things I'd try:
    1. Doing a Edit->Hierarchy->Tree from the source cellView to see if you can spot it that way
    2. Running "oaScan -lib Lib_B -cell ... -view layout" on each of the cells in lib B that it's copying to see if it spots any "header" references that have got messed up (I've seen this happen sometimes where an empty header reference is left). If it reports any such references, run again with -repair to fix them. (the oaScan is run from the UNIX command line)
    It might be something else, but it's hard to know without seeing the data - so contacting customer support would be best.
  • chenyanw
    chenyanw over 4 years ago in reply to Andrew Beckett
    Thanks for your reply! Sorry I didn't get an email notification and just saw you had replied me. I had done #1 before I posted and it didn't show any Lib_A reference.
    I just did #2, and it doesn't seem like there's any error to repair:
    No inconsistencies found in 1 database
    - found in 0 of 1 design
    My colleague has contacted support (case number 46569396 ) Hope they can help us figure out why! :)
    Andrew Beckett over 4 years ago in reply to chenyanw
    OK - I took a quick look at the case and it appears progress is being made (although it doesn't sound precisely like what you've described - it seems to be mainly concerned with the behaviour when you have constraint views during copy). Anyway, support is the right way to handle this issue, so glad it's progressing.
  • chenyanw
    Thank you Andrew. We did have a constraint view but it was not in the views to copy list in my Copy View snapshot. Also the layout had constraints yes but as I mentioned got deleted before the copy operation. That's why I didn't mention it here.
