  3. Virtuoso Error
  • Views 14421
Virtuoso Error
omiya
omiya over 4 years ago
Hi All,
I am trying to integrate "IC618" with a180nm standard PDK. When I am tying to launch Cadence with the command "virtuoso &" it is giving this message:
"/opt/cadence/installs/IC618/tools.lnx86/dfII/bin/64bit/virtuoso: error while loading shared libraries: libPolyBool.so: cannot open shared object file: No such file or directory"
Can you please help me out with this? Thank you.
    That's rather odd because libPolyBool.so is included in the IC installation under <ICinstDir>/tools/lib/64bit and should be picked up by the standard wrapper (assuming that you're running virtuoso by having <ICinstDir>/tools/dfII/bin in your path).
    Please contact customer support.
  • omiya
    omiya over 4 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you for your prompt response. I am wondering where I should contact to report my problem. I am new to this system, therefore it would be great if you could help me out. Attached is the screenshot of my cases window.
    Andrew Beckett over 4 years ago in reply to omiya
    Go to Cases->Submit Case.
  • omiya
    I am only finding the view requests option as a dropdown of cases. I am not finding the submit case option. Can it be the case that I am not eligible to submit the cases? Please let me know.
    ShawnLogan over 4 years ago in reply to omiya
    Dear omiya,
    Did you sign in as a Cadence user by creating a Cadence account?
    If you did, please see the screenshot I included as Figure 1. If you have signed in and you place your mouse over "Cases", there should be two options - "Submit Case" and "View Requests". Choose the former.
    Shawn
    Figure 1
    Andrew Beckett over 4 years ago in reply to ShawnLogan
    My guess is that you're from an academic institution and so have a limited access account on support.cadence.com? If so, you may need to go through your university contact who has a full account, or via Europractice if under that University scheme.
