  3. how to add printf statement to .cdsenv file?
  • Views 12033
KurtKimber1
KurtKimber1 over 4 years ago
Is there a way to put a printf statement in a .cdsenv file?  Thanks
    No. Why would you want to? It's a file which is not code - it's a specific format with just environment variable settings.
  • KurtKimber1
    KurtKimber1 over 4 years ago in reply to Andrew Beckett
    We load several .cdsenv files and I would like to add a printf statement for debugging purposes.
    Andrew Beckett over 4 years ago in reply to KurtKimber1
    Unfortunately tracking them down can be slightly tricky. I tend to use the following approaches:
    1. Use "cdswhich -all .cdsenv" (to list all that would be loaded via the Cadence Setup File (setup.loc) mechanism; that's not always enabled, but a good way to find them if they are)
    2. Use trace(envLoadFile) (perhaps using "virtuoso -nocdsinit" to allow you to avoid the auto-loading of the .cdsinit so you can do the trace before then loading the .cdsinit manually)
    3. Use envRegSetTrigger to define a trigger function to be called when a specific tool's env var is set, and then printing out some context information at that point to try to pinpoint what is happening).
    This article might also give some useful pointers (or some of the articles it points to): Debugging Virtuoso Session – Basic Tips and Frequently Asked Questions
  • KurtKimber1
    Good stuff, as usual, Andrew.   Thanks very much
