  3. Change default increment of deriv
  • Views 13188
Holz
Holz over 4 years ago
I try to use "deriv" function to analyze the slope of some signals, I'm using transient simulation, so X-axis is time. For "deriv" function, what is the default increment or step size of the derivative function? In output setup, I simply write:
deriv(v("/cout" ?result"tran-tran"))
"/cout" is the signal. I want to change the increment to 2ps or 20ps, how should I do it?
Thanks a lot!
    ShawnLogan over 4 years ago
    Dear Holz,
    I, personally, am not aware of a "default" value for the x-axis increment if the deriv() function as x-axis can represent time or some other variable and, if time in a transient analysis, it will depend on the simulator accuracy chosen and other designer specified simulator settings. There seem to be too many options to specify a default without impinging on its accuracy. The derivative process is already considered "noisy" for any numerical simulatior.
    One method to set the time steps to values of your choosing, such as 2ps or 20 ps in a transient analysis, is to set the strobeperiod and choose that ONLY the strobepoints be saved. In this fashion, the only data points that the function deriv() can use in its calculation are the strobepoints.
    This strobeperiod option and the choice to save only the strobepoints may be accessed through the "Outputs" tab of the Transient Analysis->Options GUI. I have included this tab as Figure 1 if it helps at all Holz.
    A second way might be to use the strobeperiod of 2 ps and then use the sample() function on your strobed waveform wits a sampling time of  20 ps. Use the sampled strobed data waveform as an argument to the deriv() to use a 20 ps x-increment or the unsampled strobe data as the 2 ps x-increment.
    Shawn
    Dear Holz,
    Shawn
    Figure 1
    Andrew Beckett over 4 years ago in reply to ShawnLogan
    As Shawn said, there's no control over the x-axis increment because it uses the same increment as the source waveform - it just takes the piece-wise slope between each point. Strobing to improve the resolution could be useful if you need that (there is the strobeoutput=all option which means that you get all the strobe points and any other output points (the default behaviour is to only output the strobe points) - so you can strobe on your desired time-step, and then sample with the same time-step, but any sharp transitions will still be output). Not sure I get Shawn's point of strobing with 2ps and then sampling with 20ps - that just seems a good way of slowing the simulator down or forcing it to produce more output data than it might otherwise need to).
    ShawnLogan over 4 years ago in reply to Andrew Beckett
    Dear Andrew (and Holz),
    My motivation for this comment was to avoid running two simulations - one with a strobeperiod of 20 ps and only saved strobed outputs and a second with a strobeperiod of 2 ps and only save strobed outputs if Holz wanted to examine the output of the deriv() function using both 20 ps and 2 ps x-increments. By running a single simulation with a strobeperiod of 2 ps, and then using the sample() function to sample the 2 ps data at an interval of 20 ps, the need to run two distinct simulations is avoided.
    I hope that makes a little more sense now. My apologies for my confusing post!
    Shawn
  • Holz
    Holz over 4 years ago in reply to ShawnLogan
    Thank you both for suggestions!
    ShawnLogan over 4 years ago in reply to Holz
    Dear Holz,
    Of course - I just hope either were helpful in your study of the derivative function!! All of Andrew's suggestions are very helpful as I'm sure you now realize!
    Shawn
