  3. bandwidth function in Virtuoso calculator
  • Views 20154
sidm
sidm over 4 years ago
Hi All,
I am trying to use the bandwidth function in Virtuoso calculator in IC6.1.8
Do I have to ensure that the input signal to the bandwidth function is in a particular format like non db20 or only a magnitude function ?
When I am applying the bandwidth function to a db20 format wave then the 3db results from the calculator don't match with the visual results for me.
regards
    No, the signal should just be a normal AC signal without modifiers (the examples in the documentation show this):
    bandwidth( v( "/OUT" ) 3 "low")
    It would certainly give the wrong answer if you passed in a waveform already in dB.
  • sidm
    sidm over 4 years ago in reply to Andrew Beckett
    Thanks Andrew
