  3. How to backannotate Monte-Carlo DCOP simulation results...
  • Views 12127
How to backannotate Monte-Carlo DCOP simulation results to schematic
delgsy
delgsy over 5 years ago
I need to backannotate a single run MC simulation. It does not work nicely in my setup.
First, I need to click op on the calculator, after that the annotation pops up.
But the second time I run MC, the backannotation is not updated.
Here is a almost the same issue on a different version of virtuoso.
I use assembler, IC6.1.7-64b.500.15.
This is the MC option window.
    Normally you'd save the waveform data (as you've done), pick the Detail view in ADE XL or Assembler/Explorer, and then go over the specific Monte Carlo point you want, and on one of the results lines do Right Mouse->Annotate->DC Operating Points etc. Does that work?
  • delgsy
    delgsy over 5 years ago in reply to Andrew Beckett
    Thanks, it works!
    I will do it that way.
    Btw, from your answer at other post, you suggested to create statistical corner. running this single corner also leads to the same issue.
