  3. Is it normal for DeCap to get 0 value leakage power when...
  • Views 11459
Is it normal for DeCap to get 0 value leakage power when running liberate?
sherryshe
sherryshe over 5 years ago
Our soi DeCap with 5 terminals (VBGP/VBGN is the 5th terminal) share the same power template with standard cells, however, the leakage for DeCap is 0 value while standard cells get leakage power like 0.22345. Could you please help me find where the problem might be and how could I fix it?
Our lib goes like this:
cell (DCAP4_liberate) {
    area : 0;
    cell_leakage_power : 0;
    pg_pin (GND) {
      pg_type : primary_ground;
      voltage_name : "GND";
    pg_pin (VDD) {
      pg_type : primary_power;
      voltage_name : "VDD";
    leakage_power () {
      value : 0;
      related_pg_pin : VDD;
Our char.tcl goes like:
set_operating_condition -voltage 1.8 -temp 25
set_var extsim_exclusive 0
define_leafcell \
         -type pmos_soi \
         -pin_position { 0 1 2 3 4 }  \
         ph
define_leafcell \
         -type nmos_soi \
         nh
source ${rundir}/TEMPLATE/template180_dcap.tcl
set_var extsim_model_include ${rundir}/MODELS/include_models180.sp
foreach cell $cells {
    lappend spicefiles /my_liberate/NETLIST/${cell}.pex.netlist
read_spice $spicefiles
char_library -extsim spectre -ccs -ecsm -cells ${cells}
template180_dcap.tcl goes like:
set_var def_arc_msg_level 0
set_var process_match_pins_to_ports 1
set_vdd -no_model VBGP 1.8
set_vdd -no_model VBGN 0
set_var pin_based_power 0
define_template -type power \
          -index_1 {0.0317486 0.0677575 0.144607 0.308619 0.658652 1.40569 3}\
          -index_2 {0.0210989 0.049137 0.114435 0.266506 0.620664 1.44546 3.36632}\
         power_template_7x7
set cells {\
DCAP4_liberate\
if {[ALAPI_active_cell "DCAP4_liberate"]} {
define_cell \
       -power power_template_7x7 \
       DCAP4_liberate
  • Guangjun Cao
    Guangjun Cao over 5 years ago
    Leakage is calculated with PG pins' DC current and voltage. It is possible that a dcap cell does not have any leaky DC path from PG pins. You may check your netlist to verify this.
    Guangjun
