  3. Run Options of ADE Assembler in Cadence Virtuoso
  • Views 18352
Senan
Senan over 5 years ago
Hello
I would like to ask you about the Run Options in ADE Assembler as seen in the image below
Though I read the help but couldn't figure out the purpose of this option,
Actually, I am interested in any option that accelerates my simulation especially when I run Montecarlo or corner simulations, not sure if this can help... I usually use Job Setup to run different corners in parallel depending on the Max Jobs I set
Thank you in advance
Best Regards
    ShawnLogan over 5 years ago +1
    Dear Senan, Senan said: Though I read the help but couldn't figure out the purpose of this option, This option allows multiple Tests to run in parallel in lieu of series. Hence, if you have two tests…
    Andrew Beckett over 5 years ago in reply to ShawnLogan +1
    Most of the time people leave the Run options alone and solely control the number of jobs on the job options/policy forms. The series/parallel tends to be more useful when you are pressing the run button…
    Dear Senan,
    This option allows multiple Tests to run in parallel in lieu of series. Hence, if you have two tests defined as "Test_bench_test1" and "Test_bench_test2", with "Run in series" selected, test Test_bench_test1"  is simulated and, upon its completion, test Test_bench_test2"  is simulated. With the "Run in parallel" selected, both tests, Test_bench_test1" and Test_bench_test2" are simulated in parallel.
    Does this make sense Senan?
    Did you happen to view the Help section at URL:
    /tools/virtuoso/20.1.ISR21/doc/Explorer/chap8.html#MC_standard
    where you can set the number of iterations to that required for your statistic limit and not for a fixed number of iterations? This might save you simulation time.
    There are many other ways as well, but I am not familiar with the specifics of you simulation setup to provide any general comments - sorry!
    Shawn
    Most of the time people leave the Run options alone and solely control the number of jobs on the job options/policy forms. The series/parallel tends to be more useful when you are pressing the run button more than once. In series mode it will run through all the jobs of the previous submission first (at least until you have some job capacity free within the allowed number of parallel jobs on the job policy) and then start submitting the simulations from the second press of the run button. With "parallel" mode it will aim to run jobs from the first and second press of the run button in parallel, sharing the available number of jobs between them.
    For Monte Carlo the job policy also affects the number of parallel simulations, and normally it will group the Monte Carlo points within those parallel simulations for efficiency (there is an option when using LSCS to specify the maximum number of sequential jobs run in a single invocation of spectre so that you can force separate runs to occur - can be useful if you have some points in the distribution that take much longer to simulate than others due to convergence difficulties for example).
  • Senan
    Senan over 4 years ago in reply to ShawnLogan
    Thank you very much Shawn for your kind help, that helped me
  • Senan
    Senan over 4 years ago in reply to Andrew Beckett
    Thank you so much Andrew, it is now clear for me
    ShawnLogan over 4 years ago in reply to Senan
    Dear Senan,
    You are, of course, most welcome! I was happy to read Andrew's response was also very helpful in explaining the Monte-Carlo job policy! His guidance and insight are so valuable to all of us!
    In all, I hope you are able to decrease the time required for your Monte Carlo simulations - that was your goal and hope you could!!
    Shawn
  • Senan
    Dear Shawn
    Thank you once again,
    I read both of the comments and indeed it boosted my MC simulation time and made advantages of the parallel simulation in multi multi-run
    I do appreciate your both help and wish you nice day
    Regards
