  3. Any efficient way to do calibration using calcVal and MonteCarlo...
  • Views 12100
Any efficient way to do calibration using calcVal and MonteCarlo for tripple nested loop?
delgsy
delgsy over 5 years ago
I basically want to execute a calibrated simulation.
The inner loop sweeps the design variable.
The second loop sweeps the code.
The third loop, i.e., the outer most loop, runs the MC.
I can do this by creating multiple tests and global variables as many as the binary code combination, carrying the output to the next test using calcVal, and getting the corrected value and code at the last test.
Is there any more efficient way to do this?
I have read about run plan feature but it seems that I need to create one run for each code, cmiiw.
    Please contact customer support - I'm not sure you should need to use run plans to do this, but the precise requirement is not clear and would benefit from having an application engineer having sufficient time to fully understand your requirement and propose a solution.
  • delgsy
    delgsy over 5 years ago in reply to Andrew Beckett
    Hi..I do not think I can contact the customer support with my account. Thanks though.
