  3. Matlab Error When Starting from Assembler
  • Views 13363
strat57
strat57 over 5 years ago
I am getting a Matlab error when I try to start Matlab using the Assembler results toolbar button.  The error is an "Invalid use of operator".
I think the problem is, the run command ADE is trying to get Matlab to use, needs single quotes.  For example, it should be
run('/tmp/adeInitMatlabkn8530.m')
Is this a setup problem, or is there an environment variable or configuration somewhere that is not set correctly?
Trent
    Trent,
    It should be run with quotation marks around the temporary file name. Which IC sub-version are you using (Help->About in the CIW)? Also, which MATLAB version are you using?
    Once MATLAB is running, can you check the process command line? For example, this is what I have:
    workshop_14> ps -ef | grep axlMatlab
    workshop 96444 95423 0 06:41 pts/3 00:00:00 /export/home/apps/IC618_isr/tools/bin/64bit/cdsServIpc -c 58726 -n 5 -r 15 -x axlMatlab -desktop -r "run('/tmp/adeInitMatlabM95423.m');import('cadence.*');import('cadence.srrdata.*');import('cadence.calculator.*');import('cadence.help.*');"
    workshop_16> ps -ef | grep matlab | grep -v helper
    workshop 96445 96444 47 06:41 pts/3 00:02:01 /export/home/apps/matlab_R2021b/bin/glnxa64/MATLAB -desktop -r run('/tmp/adeInitMatlabM95423.m');import('cadence.*');import('cadence.srrdata.*');import('cadence.calculator.*');import('cadence.help.*'); -prefersoftwareopengl
  • strat57
    strat57 over 4 years ago in reply to Andrew Beckett
    Thanks for the reply.  We're using ICADVM20.1-64b.500.20.  Our Matlab version is 2018b.
    However, checking the process command line made me realize, our tools are bsub'd out to different machines (ie distributed).  The GUI seems to run on a limited capability machine with Matlab (and Spectre sims) farmed out to more capable processing machines.  I don't seem to be able to log into (ssh) the processing machines, so I can't query the process details.
    Is using a distributed computing platform likely the source of the problem?
    Trent
    Andrew Beckett over 4 years ago in reply to strat57
    Hi Trent,
    This seems unlikely, because Matlab is invoked locally - i.e. on the same machine you're running Virtuoso and Assembler interactively. It is not sent to a remote machine, mainly because it's a single interactive session that you're launching when you press the "M" button.
    I just tried with the exact same versions you are, and all worked fine for me. I don't see the quotation marks missing.
    One possibility is that you have a wrapper command around "matlab" in your environment and that is sending the job to a remote machine via bsub - if so, maybe that is messing up the quotation marks?
    It might be best to follow this up with customer support to diagnose the issue that way.
  • strat57
    Ahhh, that makes sense.  Our CAD group does wrap matlab to submit a bsub job.  I'll check the wrapper definition, but that is likely the problem.
    Trent
