  3. Maestro - Elapsed time to results
  • Replies 11
  • Views 8895
JeyJey
JeyJey over 5 years ago
Hi.
Is there a way to add elapsed time (time take to corner to run, I see it in log file) to results for test ?
Thank you in advance.
    ShawnLogan over 5 years ago in reply to Andrew Beckett +1
    Dear Andrew and JacobG, You best me to a response Andrew -which is nothing new of course for you!! However, I will add that I use this feature in all my Explorer and Assembler runs. I've added the…
    Andrew Beckett over 5 years ago in reply to JeyJey +1
    This error is not something that is in the Cadence code. It’s something in your local customisation which is presumably doing some extra checks and restrictions. You should speak to your CAD team or whoever…
    Dear JacobG, JeyJey said: I found the .cdsinit file , but it "readonly". I tried to copy the file to work directory . But after I start virtuoso I get a message " WARNING: Identified $WORK_AREA_ROOT_DIR…
    ShawnLogan over 4 years ago in reply to JeyJey
    Dear JacobG,
    I think the reason you are not seeing any of the run statistics displayed in the Results tab for your simulation is that all you did was enable the feature. If you look at the full set of commands I included in my earlier response post, there is a second command whose argument includes the specific run statistics to display. To repeat the prior entries from my .cdsint file:
     envSetVal("maestro.results" "enableRunStatisticInfoDisplay" 'boolean t)
    ; You can customize which items you would like to be displayed using ; the “defaultRunStatisticItems” environment variable like following:
    envSetVal("maestro.results" "defaultRunStatisticItems" 'string "memory,threads,jobId,host,startTime,endTime,elapsedTime")
    Did you try, or do you time to try, entering the boldfaced type command in your CIW after enabling the statistics feature and the re-run your simulation to examine the Results tab for that run to see if the run statistics are displayed with the outputs of your simulation (similar to what I showed in Figure 1 of my prior response)?
    Shawn
