  3. is it possible to pass integer to verilog-a module?
  • Views 13125
delgsy
delgsy over 4 years ago
I want to create a verilog-a module that has an integer as input and binary code as output.
it is a DAC, basically.
Later I want to be able to sweep this integer during DC analysis.
    It's an ADC, not a DAC, surely? You could easily adapt (say) adc_8bit_ideal from ahdlLib to do this, but you could also just use my bussetp component from Creating a component that allows setting a value on a bus in an analog simulation
  • delgsy
    delgsy over 4 years ago in reply to Andrew Beckett
    yes, I meant ADC.
    "You could easily adapt (say) adc_8bit_ideal from ahdlLib to do this..."
    This is my first attempt, but not sure how I can have an integer as an input instead of voltage.
    I will check your link. Thanks
