  3. Conditional netlisting of instance depending on CDF parameter...
  • Views 11897
Conditional netlisting of instance depending on CDF parameter value
JackCadnece
JackCadnece over 4 years ago
I've created a custom dcap PCELL which depending on a parameter value will add a parallel MOSCAP for max cap density or a custom min dummy structure with the intention of minimizing parasitics to substrate to make it more general purpose.
I'm wondering is it possible to conditionally include the MOSCAP when generating a netlist in such a way that depends only on parameter value the user has selected with respect to each of their schematic instances? Perhaps something like below exists?
    cdfId->simInfo->auCdl = '( nil
        condition "cdfgData->parameter->value == valueForInclusion"
I can avoid this maintaining two separate cells so if a work around would be difficult or produce other issues I haven't considered I have a solution.
Thank you in advance and best regards,
Jack
    Jack,
    The normal way of doing this would be to have a schematic PCell (and no auCdl view for the cell) so that the CDL netlister expands into the parameterised schematic, which could either have just the dcap component or the dcap plus a MOSCAP. The alternative would be to have a custom netlist procedure, but there isn't really a good way of writing custom CDL netlist procedures (it's not really documented how to do this) and also it's not good practice for a netlist procedure to output more than one instance (it can cause some challenges when mapping is required).
    You might need to have another component which serves as the primitive dcap component that can be instantiated in this schematic PCell.
    If this isn't clear, I suggest you contact customer support for some advice. It would be much easier to discuss this with some specific examples of what you've got and what you're trying to do, which we can do within the privacy of customer support.
  • JackCadnece
    JackCadnece over 4 years ago in reply to Andrew Beckett
    Thank you Andrew,
    Your suggestion sounds like what I had hoped for originally. I'll contact customer support.
    Much appreciated and Best regards,
    Jack
