  3. How cadence generate the "IP Design.XML" file?
  • Views 2336
huhushuai
huhushuai over 4 years ago
When i use Medini Analyze software to calculate the chip failure rate, it's support the IP Design.XML file import, IP Design.XML file include the DIE size information.
So, i want to know, how to use Cadence to generate the IP Design.XML file.
Attach is the Medini Analyze use manual introduction.
    Please contact customer support. I'm not sure this is a Custom IC Design question anyway - it's more related to Vmanager/Safety Planner products.
