  3. How to query the Assembler results database for an evaluated...
  • Views 14581
How to query the Assembler results database for an evaluated expression?
Brad RFeng
Brad RFeng over 4 years ago
An ADE Assembler window is open with one or more tests that are defined and enabled. The simulation has been run and the results tab shows a wave icon for each of the outputs. At this point I want to run a script from the CIW (or from elsewhere if there is a better approach) to plot the outputs. The getData() function will provide access to the psf file from where a wave object can be pulled and then plotted using plot() and this works fine on output signals. An important point to note is that the Assembler outputs setup list can contain long expressions composed of signals that are written to the psf file but the evaluated results of the expressions are not in the psf file. For example the stability factor kf which is a function of the s-parameters generated by the sp simulation is entered into the output expression box as kf(sp(1 1 ?result "sp") sp(1 2 ?result "sp") sp(2 1 ?result "sp") sp(2 2 ?result "sp")) and named myKf. If using getData() in a script I would have to first get each of the four s-parameters and then use them in a call to the built in function kf(). I don't want to hard code all the expressions in the script. I could use maeGetTestOutputs() to grab a string equivalent of the expression but then a non trivial parsing of this string would be required to recreate the function call with the correct arguments. It also seems an inefficient use of a designers time to do some much coding when the expressions have already been defined in the outputs tab and have been already been evaluated.
Another option might be to use maePlotWithPlottingTemplate() but I want to avoid using templates.
awvPlotWaveform() looks useful but it needs wave objects as input arguments. So my quandary is how to query the Assembler results database for an evaluated expression and have it return a wave that can be easily plotted?
    You can use calcVal("outputName" "testName") in the CIW to get to the results.
  • Brad RFeng
    Brad RFeng over 4 years ago in reply to Andrew Beckett
    Thanks Andrew that works well. Will calcVal or an equivalent work within a matlab script?
    Brad
    Andrew Beckett over 4 years ago in reply to Brad RFeng
    Hi Brad,
    No, it won't. If you're talking about the ADE MATLAB Integration link, there's a Cadence Change Request 1721797 asking for the ability to access any waveform output (coming from a ViVA/calculator expression) in the MATLAB integration, but it hasn't been implemented yet. There are quite a lot of duplicate requests, but feel free to contact support to ask for a duplicate to be filed on your behalf.
    Kind Regards,
  • Brad RFeng
    Can a MATLAB script be invoked from within a SKILL script?
    That's not supported via the ADE MATLAB Integration (of course, a SKILL program could invoke MATLAB using ipcBeginProcess etc but I'm sure that's not what you mean). It wouldn't link to the interface properly if done this way.
