  3. Power calculation
  • Views 12258
Power calculation
abdurrahman0234
abdurrahman0234 over 4 years ago
How I can calculate average power of the digital circuit which has 3 bit output and drawn current?
I have simulate Vdd terminal to see current in the transient simulation. But i don't know it whether is right
    If you only have a single supply source and are measuring the current through that source into the block and know the voltage, then the power will of course be V*I, and you can then use the calculator to compute the average or rms of that power. Why do you think this might not be right?
