  3. Layout Instantiation shows a line
  • Views 10594
amssshubham
amssshubham over 4 years ago
Hi All,
I see a small triangle in the bottom left corner of  instantiated  layout blocks , why am i getting this? I have encircled the region in blue. Thanks for your help!
    Options->Display->Instance Orientations has been turned on. Turn it off, and it will go away. This is also controlled via the: layout displayInstanceOrientation boolean t cdsenv setting (this might…
    cdsenv setting (this might be set in a .cdsenv or in a .cdsinit somewhere using envSetVal or leSetEnv). It might also have been stored as a property on the containing cellView, the library or the technology library that you're using.
