  3. DRC Cadence
  • Views 10910
DRC Cadence
Zahir Kaka
Zahir Kaka over 4 years ago
Hi, I use XFAB 0.18um technology.
while doing simple DRC Run of an simple inverter Layout.  I am getting the following error:
XH018 Assura Design Rules file version 8.1.1 updated on 210106
X-FAB Design Support
Reference Documents: DR_018_03 Release 8.1
****** Subset 1131 ******
WARNING Undefined purpose in dfII.
Purpose name 'DUMMY' doesn't exist, ignoring this purpose.
diff_dyi = layer("DIFF" type("DUMMY"))
Purpose name 'pin' doesn't exist, ignoring this purpose.
polypin = pinLayer("POLY1" type("pin"))
Purpose name 'TEXT' doesn't exist, ignoring this purpose.
poly_label = text("POLY1" type("TEXT"))
poly_dyi = layer("POLY1" type("DUMMY"))
Errors exist in the rules file '/home/user/Test/.xkit/setup/xh018/cadence/assura/Assura/XH018_1131/drc.rul'.
*WARNING* Failed to build VDB. Cannot submit DRC Run.
Please help me to solve this ploblem.
best regards.
Zahir Kaka
    Zahir,
    Probably you should contact X-Fab. Something looks wrong with your PDK setup, but this is an error specific to their rules. If you need help pinpointing what's wrong, I'm sure we could look at your data via customer support too.
