  3. Locating a result value from montecarlo run table in Cadence...
  • Views 12277
Locating a result value from montecarlo run table in Cadence Virtuoso
Senan
Senan over 4 years ago
I am using Cadence Virtuoso version IC6.1.8-64b.500.6,
1. I have run the Montecarlo of my designed amplifier over 200 samples plus voltage and temperature range, hence the table results are very big,
From my result yield I can see my worst results, for example, minimum GBW = 10 MHz, and I am interested on locating this corner while it is difficult to search for it manually,
is there any useful function that I can use for such a search?
2. and after I found it, how can I bring this corner to my corner setup so I can run optimization over it.
Thank you
Best Regards
    Assuming you're using Explorer or Assembler, you can pick the Detail Transpose view and then sort on any column, filter on any column. If you've plotted a histogram of the measurement, you can click on…
    Assuming you're using Explorer or Assembler, you can pick the Detail Transpose view and then sort on any column, filter on any column. If you've plotted a histogram of the measurement, you can click on the points in the histogram to cross-select the row in the results table too.
    You can create a statistical corner of that point using the right mouse button over the row in the results.
  • Senan
    Senan over 4 years ago in reply to Andrew Beckett
    Thank you, Andrew,
    That answered my question perfectly.
    Best Regards
