  3. Dynamic paramters "temp" doesn't work? (Solver = Ultrasim...
  • Views 3234
Dynamic paramters "temp" doesn't work? (Solver = Ultrasim, transient analysis)
SpiceMonkey
SpiceMonkey over 4 years ago
Hi,I am doing mixed signal AMS verification, when I use spectre as analog solver, dynamic paramters in transient analysis works.
While when I use ultrasim as analog solver, dynamic parameters doesn't work, is my software version too old? or I missed somewhat configuration, could anyone help? thank you!
[incisive152/xcelium1803 + spectre 19.1 + ultrasim 17.1]
    Andrew Beckett over 4 years ago in reply to SpiceMonkey +1
    The best thing would be to contact customer support . There is control over forcing blocks to be analog or digital with XPS, but I think it would be best to talk to us about it. Andrew
    Ultrasim doesn't support dynamic parameters in transient, so it's not supported in AMS Ultra either (note, AMS Ultra is deprecated - I believe the latest XCELIUM versions don't support it beyond XCELIUM1909.
  • SpiceMonkey
    SpiceMonkey over 4 years ago in reply to Andrew Beckett
    Thank you Andrew. For a mixed signal verification system, "RTL digital block" and "analog veriloga/verilogams/macroModel", I have set "use ++aps" and "sampled", but APS is still much slower than Ultrasim, is any other configuration to improve simulating speed?
    For the case of "RTL" + "transistor level ADC", I tried XPS but always cant achieve enough accuracy. The digital blocks in analog are timing circuits such as non-overlaping / delay units, so these timming circuit is not supposed to be digital partition? Do you have any suggestion? thank you.
    The best thing would be to contact customer support. There is control over forcing blocks to be analog or digital with XPS, but I think it would be best to talk to us about it.
