  3. Function to skip start of a signal
  • Views 13908
SteveVrk
SteveVrk over 4 years ago
For calculating certain quantities, e.g. rms voltage, I would like to skip the first, say, 10m of a signal.
Surprisingly I did not find any function which does this (like "cut" or so). In frequency domain, dft supports skipping a time!
I am aware of the setting to skip output via strobe etc. I do not want this since it would apply to all sim outputs. I would like to selectively cut a certain region of a signal via calculator function and then apply, say, stddev.
Thanks!
    ShawnLogan over 4 years ago
    Dear SteveYrk,
    Perhaps I am totally misunderstanding your question Steve and I apologize for my lack of understanding if I am!
    However, the dft() function innately allows for examining on a portion of the time domain waveform - and also implicitly provides a low-pass filter.
    1. The dft() function syntax is:
    dft(
    o_waveform
    n_from
    n_to
    x_num
    [ t_windowName ]
    [ n_param1 ]
    [ n_adcSpan ]
    => o_waveform / nil
    where n_from and n_to represent the initial and final time points respectively of your time domain waveform from which the DFT is computed. In the frequency domain, the low-pass filter the DFT implicitly provides is governed by the time span between n_from and n_to. Intuitively, any frequency domain component below this frequency will not be discernable in your time-domain sample as its period is greater than the time-domain sample.
    Once again, it may be my misunderstanding, by it appears you need to set the value of n_from to 10ms in your case to examine only the portion after 10ms.
    Shawn
    Dear SteveYrk,
    dft(
    o_waveform
    n_from
    n_to
    x_num
    [ t_windowName ]
    [ n_param1 ]
    [ n_adcSpan ]
    => o_waveform / nil
    Shawn
  • SteveVrk
    SteveVrk over 4 years ago in reply to ShawnLogan
    Hi Shawn, thanks for your response but yes, you are misunderstanding. I want a function that does the skipping in the time domain. I was saying I know that this works if I want to process data in frequency domain via dft function.
    stddev(cutSignal(v("/vout") 10m 100m))
    Thats what I want.
    Andrew Beckett over 4 years ago in reply to SteveVrk
    Use the clip function. This allows you to specify the range of the waveform you want.
