  3. The generated datasheet is (almost) empty
  • Views 13292
delgsy
delgsy over 4 years ago
I am trying to generate datasheet but the generated datasheet (xml file) only contains the name of the model libraries and global variable.
I have tried it when using circuit from Virtuoso® ADE Assembler S1 online training and from my own circuit.
This is the setup:
    Which IC sub-version are you using? I don't recall any issues with this, but maybe if you can state the version you are using I can quickly try the training course labs with that version.
  • delgsy
    delgsy over 4 years ago in reply to Andrew Beckett
    it is IC6.1.7-64b.500.15 .
    I am aware this is not the latest version, but this is the one available at my place.
    Andrew Beckett over 4 years ago in reply to delgsy
    Having thought about this with your later post, it's probably this: Datasheets in ADE XL, Explorer, and Assembler and Schematics exported to HTML only show limited text or are displayed as a blank page
  • delgsy
    It works!
    Thank you!
