  3. cadence installation issue
  • Views 13127
tawsaras
tawsaras over 4 years ago
We are trying to install and configure cadence in our system.
I have installed it using iscape.
I am getting the following error.
2022/01/25 17:15:07 WARNING This OS does not appear to be a Cadence supported Linux configuration.
2022/01/25 17:15:07 For more info, please run CheckSysConf in <cdsRoot/tools.lnx86/bin/checkSysConf <productId>
/home/eee/cadence/installs/IC618/bin/virtuoso[239]: .[80]: .[1018]: .: line 24: awk: not found
/home/eee/cadence/installs/IC618/tools.lnx86/bin/cdsGetOABinPath: 1: basename: not found
/home/eee/cadence/installs/IC618/tools.lnx86/bin/cdsGetOABinPath: 1: dirname: not found
/home/eee/cadence/installs/IC618/tools.lnx86/bin/cdsGetOABinPath: 32: [: =: unexpected operator
/home/eee/cadence/installs/IC618/tools.lnx86/bin/cdsGetOABinPath: 1: /home/eee/cds_root: not found
ERROR: Could not find Cadence installation root for
/home/eee/
Make sure that is part of the Cadence installation.
virtuoso: ERROR: No proper OA2.2 installation found. Fix the errors reported by cdsGetOABinPath.
virtuoso: INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso: See the "OpenAccess Installation and Configuration Guide" before
virtuoso: you complete the configuration step. This manual is included with
virtuoso: the Cadence product documentation.
% Exception ignored in: <_io.TextIOWrapper name='<stdout>' mode='w' encoding='utf-8'>
BrokenPipeError: [Errno 32] Broken pipe
Can you please help me with this?
    What OS are you trying to run on? What does "lsb_release -a" return in a UNIX window?
  • tawsaras
    tawsaras over 4 years ago in reply to Andrew Beckett
    Ubuntu 20.04.3 LTS
