  3. plotting output expression with "all" evalType from GUI...
  • Views 1163
plotting output expression with "all" evalType from GUI using the generated OCEAN script
delgsy
delgsy over 4 years ago
My setup works ok from GUI.
Now I am trying to run all of them using the generated OCEAN file.
So, how can I plot output expression, especially those with "all" evalType, from GUI using the generated OCEAN script?
I have the following output
and this is from the generated OCEAN.
ocnxlOutputExpr( "swapSweep((cross(VT(\"/VOUT_INV\") 0.6 1 \"falling\" nil nil nil) - cross(VT(\"/VOUT_INV\") 0.6 1 \"rising\" nil nil nil)) \"N\")" ?name "across_TOT" ?plot t ?evalType 'maa)
ocnxlOutputExpr( "average(TRAN_TOT ?overall nil)" ?name "across_mean_TOT" ?plot t ?evalType 'maa)
ocnxlOutputExpr( "stddev(TRAN_TOT ?overall nil)" ?name "across_sigma_TOT" ?plot t ?evalType 'maa)
after executing the file using load(), it finishes without error but no VIVA window is opened.
I added the following line just to check, and still no plot.
VOUT_INV = v("/VOUT_INV" ?result "tran") ; this is how I did in ADEL.
newWindow()
plot(VOUT_INV)
If I execute "plot(VOUT_INV)" on CIW, it plots the result.
