  3. Converting a pspice model to schematic/spectre (max, table...
  • Views 4350
Converting a pspice model to schematic/spectre (max, table etc)
SteveVrk
SteveVrk over 4 years ago
I would like to have this pspice circuit as a sub circuit in virtuoso:
.subckt ccm-dcm1 1 2 3 4 5 params: L=1 fs=1E6
Et 1 2 value={(1-v(u))*v(3,4)/v(u)}
Gd 4 3 value={(1-v(u))*i(Et)/v(u)}
Ga 0 a value={MAX(i(Et),0)}
Va a b
Rdummy b 0 10
Eu u 0 table {MAX(v(5), v(5)*v(5)/(v(5)*v(5)+2*L*fs*i(Va)/v(3,4)))} (0 0) (1 1)
.ends
This is what I put in the schematic editor:
And this is the netlist:
simulator lang=spectre
global 0
Ga (0 a) bsource v=MAX(i(Et),0)
Eu (u 0) bsource v=table MAX(v(5), \
v(5)*v(5)/(v(5)*v(5)+2*L*fs*i(Va)/v(3,4))) (0 0) (1 1)
Et (v1 v2) bsource v=(1-v(u))*v(3,4)/v(u)
Va (a b) vsource dc=0 type=dc
Rdummy (b 0) resistor r=10
Gd (v4 v3) bsource i=(1-v(u))*i(Et)/v(u)
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
checklimitdest=psf
dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
dcOpInfo info what=oppoint where=rawfile
Of course, the simulation fails and I think the main issue (up to this point) is the table:
ERROR (SFE-874): "input.scs" 13: Cannot run the simulation because syntax error `Unexpected open parenthesis "(". Expected equals' was encountered at line 13, column 28. Correct the syntax error and rerun the simulation.
How do I properly implement this?
    I thought I'd answered this yesterday but it seems I didn't hit the "Reply" button.
    There are several things wrong here:
    1. You can't just paste PSPICE syntax into a bsource component - they are not equivalent
    2. In particular there's no table support in bsource, and the MAX function would be called max (Spectre is case-sensitive)
    3. Also, you've changed the pin names to v1, v2, v3 etc whereas the expressions refer to v(1) v(2) etc - that would need to be v(v1) and so on.
    However, I would say there's little point in trying to translate this to a schematic - better would be to directly use the PSPICE model. To do that, simply do:
    1. Create a new cellView with Type: Pspice (the view name would usually be called "pspice") - I would recommend changing the cell name to be "ccm_dcm1" or "ccmdcm1" as a minus sign is not a great thing to have in a cell name (it might cause flow issues somewhere)
    2. Paste in the model code into the text editor that appears (again, changing the subckt name to match the cell name you picked in step 1)
    3. Press the "Build a database" button (the save icon with the green checkmark) or File->Extract (they're the same)
    4. It will check all is OK with the model, and ask you to generate a symbol (which will have pins called 1,2,3,4,5 etc) - move to whichever side of the symbol you want
    5. You can then place an instance of this symbol in your circuit
    6. In ADE, if using a config view then set the "view to use" of the component to be "pspice" or if not using a config view ensure that "pspice" is in the View List in Setup->Environment - this gets the netlister to look at the pspice view
    That's it. No translation to other languages needed - Spectre supports a large proportion of the PSPICE language, so you might as well use the model directly.
