  3. Variables in the SPEC section of Cadence Explorer
  • Views 14783
mhkvy4
mhkvy4 over 4 years ago
Hello everyone,
I am using Virtuoso IC 6.1.8.
In explorer in the outputs setup tab, can we include a pre-defined expr name in the SPEC column. For example I have my VIH_spec as the name of the expr and in the details the equation calculating VIH_spec as (0.7 * VAR("Vsupply")).
I cannot seem to include the value of VIH_spec calculated above as the spec for another expr.
    ShawnLogan over 4 years ago
    Dear mhkvy4,
    How are you referring to your first expression? Are there any spaces in your expression name? I just tried your expression and set the spec for a second expression to be a function of the first specification and it appears to work as shown in Figure 1. I am using:
    $ virtuoso -W
    sub-version  ICADVM20.1-64b.500.22
    Shawn
    Figure 1
  • mhkvy4
    mhkvy4 over 4 years ago in reply to ShawnLogan
    Hi sorry to bump this old thread.
    Shawn, if I have the spec including VAR like you do for output_noise_1 then it works. If I have the expr name in my spec column (like you do for output_noise_2, referring to output_noise_1) then I don't get the right result. It shows that I failed the spec even though I passed it
    Andrew Beckett over 4 years ago in reply to mhkvy4
    It also doesn't work robustly for me either. If you use "re-evaluate" it fails with an error, and during simulation I too get a failed spec even though it should have passed.
    Instead of having just referred to output_noise_1 directly, use calcVal("output_noise_1") in the spec; that seems to work correctly (I can see both passes and fails with the correct limits if I do that).
  • mhkvy4
    mhkvy4 over 4 years ago in reply to Andrew Beckett
    Hi Andrew.
    I just tried it out and calcVal does indeed work. Thanks for your help.
