  3. Applying multi-bit VCSV files in analog virtuoso schema...
  • Views 11424
Applying multi-bit VCSV files in analog virtuoso schematic
Johanny Saenz
Johanny Saenz over 4 years ago
Hi all.
Is there a way to apply a multi-bit VCSV file in analog schematic as stimulus?
My file contents are like:
;X, Y
;Re, LogicBus
;time, LogicBus
;s, yunit
0,xxxxxxxx
2e-07,00000000
0.002012000333,xxxxxxxx
0.002024000333,00000000
0.002420000333,01101100
0.002432000333,01100011
0.002444000333,01100101
    No. You could use the .vec (vector file) instead and I'm sure you could convert from the VCVS format into the vector format (covered in the Spectre documentation) with only a little bit of processing (perl, python etc). Note that the vector file needs some additional information to define the high and low voltages, rise/fall times etc.
