  3. desVar interdependencies in maestro
  • Views 13004
Ymmen
Ymmen over 4 years ago
hi,
In maestro view (ADE Explorer) I have defined desVar "Vin1" which is a function of another desVar "Pin1".
Pin1 = -40
Vin1 = sqrt(2*50*10**((Pin1-30)/10))
In HB analysis when I sweep Pin1 from -40 to 0, I see Pin1 sweeping but Vin1 evaluates 3.16e-3 which corresponds to Pin1=-40. In other words, Vin1 does not change its value with the sweep. This problem is seen in maestro. ADEL didn't had this issue. In picture attached I have added netlist and maestro view.
Is there a way we can enable desVar interdependency so that if one of them is swept, the other updates automatically?
virtuoso: IC6.1.8-64b.500.20
spectre: 19.1.0.373.isr7
Fullscreen 0714.netlist.txt Download
// Point Netlist Generated on: Feb 24 09:19:28 2022
// Generated for: spectre
// Design Netlist Generated on: Feb 24 09:19:28 2022
// Design library name: NUECES_ygoel
// Design cell name: HB_plots
simulator lang=spectre
global 0
parameters Pin1=-40 frf1=1G Vin1=3.16227766016838e-3
// Library name: NUECES_ygoel
// Cell name: HB_plots
// View name: schematic
PORT1 (net2 0) port r=50 type=sine
PORT0 (net1 0) port r=50 type=sine freq=frf1 ampl=Vin1
R0 (net1 net2) resistor r=1m
    iabstol=1e-12 temp=27 tnom=27 homotopy=all scalem=1.0 scale=1.0 \
    gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 digits=5 cols=80 pivrel=1e-3 \
    sensfile="../psf/sens.output" dochecklimit=yes checklimitdest=both \
    bsimsoi_va=yes disk_check_thresh=1.048576e+08
sweephb  sweep  param=Pin1  start=-40  stop=0  step=20  {
  hb  hb  tstab=0  oversample=[1]  fundfreqs=[(frf1)]  maxharms=[5]
+   errpreset=moderate  annotate=status
asserts info what=assert where=rawfile
saveOptions options save=selected
    ShawnLogan over 4 years ago
    Dear Ymmen,
    It appears there is a known deficiency in IC6.1.8 shown at the following URL:
    support.cadence.com/.../techpubDocViewerPage
    and included below for your convenience. In your case, have you set Pin1 as a global variable?
    CCR 875662: A dependent expression always takes values from the global variable even if the local variable is enabled for a test
    Description: If a dependent expression is based on a variable that is overridden and enabled at the test level to use its local value, its output incorrectly uses the value specified for that variable at the global level.
    Solution: To use the local value in the dependent expression, define the expression inside another variable defined at the test level.
    Shawn
  • Ymmen
    Ymmen over 4 years ago in reply to ShawnLogan
    Thanks for the reply Shawn. In my case, I am using ADE Explorer instead of ADE Assembler. So I think In my case all design variables are local and there is nothing defined as global variable. Pin1 is not defined explicitly as global variable.
    given info above, "Vin1" should have depended on "Pin1", as PIn1 is not defined as global variable?
    you can see the screenshot of maestro (ADE explorer) view in my first post.
    Andrew Beckett over 4 years ago in reply to Ymmen
    This is a bug. We've had some challenges in certain cases where dependent variables are prematurely evaluated, which breaks a variable being swept as in this case. The challenge is that you can have SKILL expressions in ADE which have to be evaluated before simulation, but some expressions could be handled by the simulator (such as these) and if you want to sweep one of the dependencies you really need it to be deferred.
    I'll file a CCR for this specific case (since I created a testcase to try it out). You can workaround it by using this instead:
    (2*50*10**((Pin1-30)/10))**0.5
    It seems to be the sqrt that is causing the trouble.
  • Ymmen
    Ymmen over 4 years ago in reply to Andrew Beckett
    Thanks for the workaround Andrew. it would be great if you can post the CCR number once you file it. that way I can track it and apply the fix whenever available.
    The CCR is 2619468. To track this, you'll need to log a case with customer support and request that a duplicate is filed on your behalf.
