  3. simulation not running when starting a new test simulat...
  • Views 11875
simulation not running when starting a new test simulation
dileeps
dileeps over 4 years ago
I am using the version: 6.1.8.230 of cadence.  I have different tests in my maestro view and when I try to start a new test simulation, different to one which is already running, it freezes after finishing net-listing and does not start the simulation run. This happens when I start to run an ac/pss/trans simulation while a different type of simulation is already running.
I use job control mode LSCS with maximum number of jobs as 6 which is more than the required at that moment.
I saw this behaviour when I have the output log file from previous interaction kept open.
Do you know what is happening and how it can be resolved quickly?
Thanks and regards,
Dileep S
