  3. Changing the legend position in the Cadence results
  • Views 13800
Senan
Senan over 4 years ago
Hello
I am using the Cadence Virtuoso version IC6.1.8-64b.500.6
I am facing a problem when trying to change the legend position from my result graph, for example if I want to change it form the default to the top or inside, I go to the graph properties then change the legend position to above.
in the picture below is how my graph will look like
Now I have saved the image to my local computer using the following setting
However, after I opened the saved image, the legend is disappeared as you can see from the picture below
you see on the image is written "more" but not presenting the legends
Thank you
Best Regards
    Andrew Beckett over 4 years ago in reply to Senan +1
    Senan said: I tried to find the option where I can change the backround colour for specific results by going to Graph properties, but I am not able to find such an option. Use Edit->Multi Graph Properties…
    I'm surprised that this has not been noticed before (I can't find a report of the problem). It works OK with Render exactly as on screen, but not with that turned off. It's still broken in the latest IC6.1.8 ISR (ISR23). So I filed a change request, CCR 2617845 to get this fixed.
  • Senan
    Senan over 4 years ago in reply to Andrew Beckett
    Thank you Andrew for your help,
    I have tried your solution and it is now working as you can see from the image below
    However, with "Render exactly as on-screen" restrict me from changing the graph background, hence it comes in back as my original graph is in black.
    Could you please help me to find this option from the GUI?
    Another problem I have found is related to the choice of "inside" for the legend, once I choose it I loose totally my legends as you can see from the following image
    Thank you once again
  • Senan
    Senan over 4 years ago in reply to Senan
    By the way, The option of "Render...." dosenot support saving the image in pdf format!
    Use Edit->Multi Graph Properties to change the background colour.
    I agree, the "render as" doesn't help with PDF - it was certainly an imperfect workaround.
  • Senan
    your answers covered my inquires
    Best Regards
