  3. AMS simulation error: "ncsim: *F, INTERR: INTERNAL EXCEPTION...
  • Subscribers 128
  • Views 4036
AMS simulation error: "ncsim: *F, INTERR: INTERNAL EXCEPTION"
LIUYI
LIUYI over 3 years ago
My virtuoso version is 6.1.8-64b. And my AMS simulator is "incisiv152hf".
When I use the AMS to simulate the analog part and digital part together, some error happens.
Actually, I used TSMC28nm technology PDK. Whenever I put some transistors from this pdk, and do AMS simulation with verilog file, it will stop because of the following problem.
Could you help me to solve this problem?
Thanks very much.
  • LIUYI
    More details about the version:
    virtuoso: IC6.1.8-64b.500.19
    ncsim(64) 15.20-s080.
    Thanks.
    Andrew Beckett over 3 years ago in reply to LIUYI
    From the message, it seems that the version of Spectre integrated into INCISIVE152 is too old - not surprising, since it's a release that came out in 2015 and you're using newer TSMC (TMI) models.
    You should move to using a recent XCELIUM release (note, if you move to the latest XCELIUM2109 you'll also need to update to the latest IC618 hotfix). It certainly makes no sense using such an old simulator release when your IC release is very recent (from during 2021).
  • LIUYI
    LIUYI over 3 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thanks for your kind help. I will ask our software team to update.
    Best Regards,
    Yi.
