  3. Datasheet plots differently from Plot All result if using...
  • Views 10639
Datasheet plots differently from Plot All result if using a Plotting Template (ic6.1.8.500.22)
StephanWeber
StephanWeber over 4 years ago
I created a plotting template in Assembler and get nicely a subset of my output curves with nice re-arrangements acc. to my template. Note: Some curves have been deleted in the template to focus on the key plots only.
However, if I now create a datasheet with using this template I got something different:
I got the re-arranged plots as desired, but I got also plots which (as intended) do not appear with plot all.
So the datasheet contains a bit more than I want.
Note: I managed to let the datasheet truly recognize the template (e.g. I disabled the use quick plot data). I also tried use current Viva (but this makes no difference on plotting too much into  the datasheet)
Bye Stephan
    Stephan,
    Please contact customer support. This has probably come up before but I certainly don't have the bandwidth at the moment to check - but somebody in the team can certainly look into this.
