  3. Generating HSpice Netlist from Schematic in Virtuoso
  • Views 12192
Sanjana8
Sanjana8 over 4 years ago
I was working with a basic AND2x1 which I created using INVx1 and NAND2x1, all of the cells mentioned  I drew in the schematic generated the symbols attaching to an existing library of NCSU_TechLib_ami06 and using NCSU_Analog_Parts. I wanted to generate hspice netlist from ADE simulation. I worked with sepctre before and it successfully generates the netlist and simulation waves for me. But whenever I try to do the hspice simulation even setting the correct model libraries of hspice standalone it is giving me the error below. I am a bit lost as to what I should be doing here to rectify this.
Thank you so much for your help.
