  3. MAESTRO CORNER SETUP
  • Subscribers 136
  • Views 14544
JeyJey
JeyJey over 4 years ago
How can I define set corners not by multiply number of variables, but as "parallel" set.
Not to run 25 corners , only 5 : 0 -0 , 1-1, 2-2, 3-3, 4-4, 8-8.
This option was in old ADE in parameter analysis with "run mode" list.
Thank you in advance
  • Frank Wiedmann
    Frank Wiedmann over 4 years ago +1
    In Maestro, these are called Parametric Sets, see https://support.cadence.com/apex/techpubDocViewerPage?path=Explorer/ExplorerIC6.1.8/chap5.html#pgfId-1008621
    Andrew Beckett over 4 years ago in reply to Frank Wiedmann +1
    Frank, you beat me to it. There is a little more info that might be useful though. For design and global variables, and parameters, you can select them and then right mouse->group as parametric set …
  • Frank Wiedmann
    For design and global variables, and parameters, you can select them and then right mouse->group as parametric set (in the data view assistant). For corners (in the corners setup UI), there's no "group as parametric set" option (unfortunately - there is however an enhancement request asking for that), but instead you can use right mouse->Expand Corner Selectively->Selected Paramset. With the choices you have shown above, that would expand to 5 corners.
