  3. automatic routing using specific metal layer
  • Views 12207
delgsy
delgsy over 4 years ago
How can I tell cadence to do automatic routing using certain metal layer only, e.g., only metal2 and metal3 ?
Which documentation should I consult to regarding this?
I found some explanation about routing in Virtuoso Space-based Router User Guide but not in Layout XL User Guide.
please excuse me if this turns out to be basic question.
    The easiest way to control this is to use Window->Assistants->Wire Assistant, and then you can specify the Top and Bottom "Routable" layers. If you're routing a single net, you can do that from the Navigator, and use Right Mouse->Route with WA Overrides (WA is "Wire Assistant"). Or you can use the routing buttons in the Wire Assistant.
