  3. Layers visibility issue in hierarchical layout design
  • Views 11045
Senan
Senan over 4 years ago
I am in the second hierarchical level of my layout design, I have inserted a layout block from the first hierarchical, I did it from "Connectivity"> "Generate" > "Selected from source".
The layout block came but I am missing to see many layers, e.g, poly, contacts, pins, wells and labeles. Even thaugh I have set the stop of the Display Layers to 32.
I am using Cadence Virtuoso version IC6.1.8-64b-500.6
Thank you
Best Regards
    Please contact customer support . Trying to guess what you're doing wrong is going to be rather hard without seeing it. Andrew
    Please contact customer support. Trying to guess what you're doing wrong is going to be rather hard without seeing it.
  • Senan
    Senan over 4 years ago in reply to Andrew Beckett
    Thank you  Andrew,
    I will contact them,
    Best Regards
