  3. Importing Digital Standard Cells from PDK data
  • Views 12775
Matthias Ochs
Matthias Ochs over 4 years ago
Hello everybody,
I have some problems including the digital library with the standard cells in it in Virtuoso (same accounts for the standard IO-library).
I have included the cds.lib files from this PDK which was fine. Problem: Contrary to the other processes I know, there is only a symbol in it (no schematics and layout).
What I would like to have are symbol+schematic+layout (ideally).
What I have understood so far is that I can include the schematics from the cdl-file with all the subcircuits.
I used Spice-In with the options:
- Netlist language CDL refering to the netlist file
- Import Sub-circuits List: empty (I want to include all)
- Reference Library list: I referenced the library created with all the symbols (called it PDK_digital), and the library which contains the transistor models (PDK).
- I have no device mapping file (I guess here is the problem, but the mapping should be straight-forward, since I have one symbol which has the same name as the subcircuit-entry in the cdl file).
- Output library is the library with the digital symbols (PDK_digital). I also tried it with a new library
Problem: Nothing happens
Log file:===================
Spice In Log File
Parameter file: /tmp/spiceInPn57939
Import Parameters:
    Netlist file name: /nas/ei/share/pdks/GF/GF22FDX_SC8T_104CPP_BASE_CSC20SL_FDK_RELV06R50/cdl/GF22FDX_SC8T_104CPP_BASE_CSC20SL.cdl
    Output library name: cmos22fdsoi_digital
    Output View Type: schematic
    Schematic view name: schematic
    Netlist view name: netlist_tmp
    Reference Library List: cmos22fdsoi cmos22fdsoi_digital cmos22fdsoi_digital
    Device-mapping not enabled.
    Master Cell for Ground: gnd
    Cells to be Overwritten: <all>
    Schematic Generation parameter file: /tmp/schOpts_spiceInPn57939
    Simulator: spectre
    Output Simulator: spectre
    paramCaseValue: default
    Parser: ASSURA
    Language: CDL
WARNING (SPICEIN-99): 'Import Subcircuit List' is not found in the specification, hence setting it to
default empty value and importing all sub-circuits in the netlist.
INFO (SPICEIN-100): SpiceIn successfully parsed the cdl netlist file '/nas/ei/share/pdks/GF/GF22FDX_SC8T_104CPP_BASE_CSC20SL_FDK_RELV06R50/cdl/GF22FDX_SC8T_104CPP_BASE_CSC20SL.cdl'.
Importing SUBKCT 'tdndsx' in Library 'cmos22fdsoi_digital'
    Master Cellview Found in cmos22fdsoi::tdndsx::symbol
    Skipping import for subckt: tdndsx
Basically all cells are skipped.
For the layout I am completely blank, there is a huge gds file in the pdk directory.
Is there a straight forward way to include the files? I would be very thankful if anybody can help with this process.
Kind regards,
Matthias
