  3. Keysight ADS schematic into Virtuoso
  • Views 12434
sidm
sidm over 4 years ago
Hi All,
is there a way to bring in Keysight ADS schematic (originally created in Virtuoso and exported to ADS using the dynamic link option ) back into Virtuoso ?
No major changes were done after exporting the Virtuoso original schematic into ADS except for adding 10port s-parameter block and manually stitching this block.
I am using IC 6.1.8 500.19
regards
    If it's in OpenAccess format it's probably straightforward - just open it. However, for anything else, please contact customer support.
  • sidm
    sidm over 4 years ago in reply to Andrew Beckett
    ok thank you very much
