  3. Issue with importing csv file to the ADEXL outputs
  • Replies 12
  • Views 16814
greywanderer
greywanderer over 4 years ago
I have transistors in the schematic named Mxx<5:0> and want to observe the "gm" of Mxx<5>. After accessing this in the results browser and storing in the outputs and then exporting it as a csv file, the transistor appears as "Mxx\\<5\\>". But when I make similar modifications to the rest of the occurrences in the csv file and import it to the output of the adexl, I get the following error,
value(pv("Mxx\<
PARSER WARNING at line 1 column 28 of file *string*
*WARNING* (Parser): character found after backslash is not meaningful - '\<'
What am I doing wrong? Any suggestions on managing such name formats in the csv files for the ADEXL outputs?
Thanks!
    Andrew Beckett over 4 years ago in reply to greywanderer +1
    Doing all this messing around with nmp or looking up netlist names really should not be necessary. Sorry, Shawn, but you first suggested using the names in the netlist, and then suggested checking for…
    The challenge appears to be if the expression is in quotes (and you have the "escaped" quotes embedded within). If it's like this:
    library:cell:test,Ids0p5u_Mnb5,expr,value(pv("ux1.ux2.Mnb\\<5\\>" "ids" ?result "tranOpTimed") 5e-07),t,,
    then it works with no problems.
    If you have the surrounding quotes in place, there's an extra layer of parsing, so that means you need to double-up the backslashes to (yes) four!
    library:cell:test,Ids0p5u_Mnb5,expr,"value(pv(""ux1.ux2.Mnb\\\\<5\\\\>"" ""ids"" ?result ""tranOpTimed"") 5e-07)",t,,
    The joys of escape characters!
  • greywanderer
    greywanderer over 4 years ago in reply to Andrew Beckett
    I see. The double quotes were placed there when I exported to a csv file and I assumed they needed to be so.
    Thanks much!
