  3. Issue with importing csv file to the ADEXL outputs
  • Replies 12
  • Views 16813
greywanderer
greywanderer over 4 years ago
I have transistors in the schematic named Mxx<5:0> and want to observe the "gm" of Mxx<5>. After accessing this in the results browser and storing in the outputs and then exporting it as a csv file, the transistor appears as "Mxx\\<5\\>". But when I make similar modifications to the rest of the occurrences in the csv file and import it to the output of the adexl, I get the following error,
value(pv("Mxx\<
PARSER WARNING at line 1 column 28 of file *string*
*WARNING* (Parser): character found after backslash is not meaningful - '\<'
What am I doing wrong? Any suggestions on managing such name formats in the csv files for the ADEXL outputs?
Thanks!
    Andrew Beckett over 4 years ago in reply to greywanderer +1
    Doing all this messing around with nmp or looking up netlist names really should not be necessary. Sorry, Shawn, but you first suggested using the names in the netlist, and then suggested checking for…
    ShawnLogan over 4 years ago
    Dear greywanderer,
    Have you inspected the spectre netlist to determine the name of the transistor and its syntax (not the calculator expression)?
    I usually use the syntax from the spectre netlist since that is a valid syntax.
    Shawn
  • greywanderer
    greywanderer over 4 years ago in reply to ShawnLogan
    The spectre netlist has "Mxx\<5\>". And I see the same error as mentioned above when I use this format.
    ShawnLogan over 4 years ago in reply to greywanderer
    Dear greywander,
    Have you tried using the CDBA syntax checker nmp? I tried it using your syntax and your syntax appears illegal. I might suggest you try the alternative syntax I show which is legal:
    $ nmp isLegalName CDBA  "Mxx\<5\>"
    illegal
    $ nmp isLegalName CDBA  "Mxx|5|"
    legal
    Shawn
    PS. This tool is detailed at the Cadence on-line support URL:
    support.cadence.com/.../ArticleAttachmentPortal
  • greywanderer
    value(pv("Mxx|5|" "ids" ?result "tranOpTimed") 5e-07)
    This does not work either.
    Doing all this messing around with nmp or looking up netlist names really should not be necessary. Sorry, Shawn, but you first suggested using the names in the netlist, and then suggested checking for CDBA legal names (CDBA names are what appears on the schematic, not in the netlist). So that's conflicting advice. I would try to use schematic names wherever you can, so that you're not at the mercy of how names get mapped in the netlister (and most of the time this is a reasonable strategy unless you are trying to access something that doesn't correspond to a schematic element - e.g. within a subckt model).
    If it's a schematic name (and using outputs(?result 'tranOpTimed) in the CIW should show you the schematic names) then you just need to start the name with a / and use / as the hierarchy separator. If the name ended up in the netlist as Mxx\<5\> (which I'd expect) then because backslash is an escape character in SKILL, to truly get it you need a double-backslash.
    So using something like this in your CSV should do it:
    Name,Type,Output,EvalType,Plot,Save,Spec
    mxx5_gm,expr,value(pv("/Mxx<5>" "gm" ?result 'tranOpTimed) 2e-07),point,t,,
    mxx5_gmnet,expr,value(pv("Mxx\\<5\\>" "gm" ?result 'tranOpTimed) 2e-07),point,t,,
    mxx4_gm,expr,value(pv("/Mxx<4>" "gm" ?result 'tranOpTimed) 2e-07),point,t,,
    mxx4_gmnet,expr,value(pv("Mxx\\<4\\>" "gm" ?result 'tranOpTimed) 2e-07),point,t,,
    The _gm are schematic names, and the _gmnet are netlist names (note the double-backslash). Having a single backslash in the string would be a problem because SKILL will try to read the < or > as escaped, which doesn't make sense - hence the parser error.
    By the way, you can also see the netlist names you could use by typing: outputs(?map nil ?result 'tranOpTimed) in the CIW.
  • greywanderer
    greywanderer over 4 years ago in reply to Andrew Beckett
    As I had mentioned in the parent message, I saw the double backslashes when I exported to csv. But it did not work when I imported after changes to other outputs.
    For whatever reason, both your suggestions are working now. I dont know what I might have done wrong.
    Thanks for being so free with your knowledge. I did not know about getting netlist names with outputs() among other things.
  • greywanderer
    Hi Andrew, Shawn,
    Sometimes when using netlist names, there is a problem with the import of the csv file and it misses the double back slashes giving the error below. I will use the schematic names for now. Just thought you might be interested.
    "value(pv("Mxx\<
    *WARNING* (Parser): character found after backslash is not meaningful - '\<'"
  • greywanderer
    greywanderer over 4 years ago in reply to greywanderer
    Looks like you are recommending to use the schematic names wherever possible.
    I would generally go with the schematic names out of choice. However, the failure you mention with netlist names - this should work. So please post the relevant line from the CSV and the IC sub-version you're using, and I can check if it's something wrong with the CSV or there's a bug.
  • greywanderer
    This is the line from the CSV
    library:cell:test,Ids0p5u_Mnb5,expr,"value(pv(""ux1.ux2.Mnb\\<5\\>"" ""ids"" ?result ""tranOpTimed"") 5e-07)",t,,
    The IC sub-version,
    Just want to clarify that this works sometimes and doesn't work sometimes.
