  3. How can I combine Multipart Path from several .il files...
  • Replies 9
  • Views 14664
How can I combine Multipart Path from several .il files?
delgsy
delgsy over 4 years ago
There is this big guard ring that consists of 5 types of smaller guard ring.
I have made 5 .il files and they work individually.
I prefer not to apply them one by one every time I need to create the big guard ring.
One thing that I tried is to put the below script into one .il file and execute the file.
It just loads the individual files, but it does not work as expected, obviously.
load("guard_ring_1.il")
load("guard_ring_2.il")
load("guard_ring_3.il")
load("guard_ring_4.il")
load("guard_ring_5.il")
Is there a way to do this?
    Andrew Beckett over 4 years ago in reply to delgsy +1
    I don't have anything to do the wrapping part (although that's potentially not that difficult if you can compute the bBox of the objects or maybe the bBox of a particular layer within the instances to…
    I'm not sure why it's obvious that this wouldn't work but perhaps that's because my ESP capability is in for repair and so I have no idea what your code is actually doing! I don't think anyone will be able to answer this without having some clue as to what's in your guard_ring_N.il files.
  • delgsy
    delgsy over 4 years ago in reply to Andrew Beckett
    One of the smaller guard ring is like this, the other ones are modification of it using different layer(s) and sizes. I created all of them from Multipart Path.
    Here is one of the examples. This consists of only 1 layer.
    prog((tech techLibName techFileName)
    techLibName = "tech_name"
    techFileName = "tech.db"
    tech = techOpenTechFile(techLibName techFileName "r")
    if(tech==nil then
    return(nil)
    ;The template name is : my_template
    leDefineMPPTemplate(
    ?techId tech
    ?name "GR_JT_2u_separation"
    ?layer list("JT" "drawing")
    ?width 2.000000
    ?choppable t
    ?endType "truncate"
    ?beginExt 0.000000
    ?endExt 0.000000
    ?justification "center"
    ?offset 0.000000
    ) ; end of leDefineMPPTemplate procedure
    ) ; end of prog in ASCII file
    This is the big guard ring that I mentioned earlier.
    OK, so those just define the templates. What's the problem with loading several files - surely it will just define all the templates?
  • delgsy
    Yes, that only loads all the 6 templates.
    Excuse me for not being more clear.
    With these templates I need to create smaller guard ring multiple times in order to create the big guard ring.
    I upload the big guard ring in previous reply.
    What I am trying to do is creating the big guard ring in smallest number of steps.
    You either need to come up with a more complex template that includes all these rings, to write some SKILL code that creates the multi-part path as you wish, or create a fluid guard ring PCell (easiest with PCell Designer) that has all the flexibility you need. You're not going to achieve that just by loading several templates.
  • delgsy
    What is the the name of licence for Pcell Designer?
    I just want to make sure if I have it.
    From here, I got some info about Pcell Designer. I checked on CIW-->Tools and did not find Pcell Designer.
    I checked also in CIW-->Options-->Licence, there is no names resembling Pcell Designer.
    It's unlikely you have a license without having installed it - it's a separate (very small) installation (the PCD25 release on downloads.cadence.com ) which is then loaded via your .cdsinit. The license doesn't show up in the license UI, but if you look in your license file it would show the feature "Pcell_Designer".
    You should contact your account manager/team at Cadence as we normally would have a specific discussion about how best to use the PCell Designer technology.
  • delgsy
    Is there SKILL code/command to automate the MPP Guard Ring creation? I cannot find it in the SKILL reference doc.
    It actually works well but I need to select instance and shift+G multiple times.
    I don't have anything to do the wrapping part (although that's potentially not that difficult if you can compute the bBox of the objects or maybe the bBox of a particular layer within the instances to compute the bounding box (maybe with some over-sizing to allow margins) and then use Can I create a Multi Part Path in SKILL based on a technology file template? to create the MPP based on a template using SKILL.
