  3. psf utility
  • Views 15185
psf utility
Driss
Driss over 4 years ago
Hello
I am trying to understand the use model of the psf command line.
I can extract data from the psf database and export them text files, but can't really understand how to interpret the output format.
Does anybody have ressources/documentation on this tool ?
Any help is appreciated.
Thank you in advance
Cedric.
    Cedric,
    I'm not sure the "psfascii" format is published; the "psf" tool is mostly there for debug purposes and its use and output is not documented (as far as I know; I don't think it's been added while I wasn't looking).
    ShawnLogan over 4 years ago in reply to Andrew Beckett
    Dear Cedric,
    You might consider a few things:
    1. There is a Forum post discussing the use of the command a number of years ago at URL:
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/31155/no-waveform-data-when-using-psf-command
    2. Secondly, the psf utility (as noted in [1]) will only work with the psf formatted data bases - not, for example, psfxl. Hence, you will need to force the output format to "psf".
    3. The help menu for psf is still available with the UNIX command "psf -h" when invoked from your Cadence session.
    4.  More modern means of creating an ASCII waveform exist through the srrutil utility and the use of the SKILL proceedure
    "rdbWriteToFormat" SKILL function  described at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nWAEEA2&pageName=ArticleContent
    The srrutil utility is located in your Cadence directory at:
    $CDSHOME/tools.lnx86/dfII/bin/64bit/srrutil
    and its help menu is invoked by srrutil -h. A copy of the resultant command to access the help function and the help contents are shown for my installation in the text file below.
    Hope this helps Cedric!
    Shawn
    Fullscreen srrutil_help.txt Download
    $  /tools/virtuoso/20.1.ISR23.EHF020722/Linux/tools.lnx86/dfII/bin/64bit/srrutil -h
    usage: srrutil [options...]
    COMMANDS
    	# Prints version
    	srrutil -v
    	# Prints this help
    	srrutil -h
    	#Prints information about data base using SRR driver
    	srrutil -info -dbase <psfDir> -print-signal -print-value [-max-nb-signal <nb>] [-dataset <dataset>] [-print-wfibute] -read-only -read-hier [-no-print-datset-info]
    	#Prints type/version of dataset in the current psf directory
    	srrutil -dataset-type -dbase <datadir> [-dataset <dataset>]
    	# Exports transient signals into individual dataset (in psfxl)
    	srrutil -export -dbase <psfDir> -dataset <dataset> -signal <signalName> [-raw outdir] [-o outfname]  [-format vcsv json canvasjs] [-range min max] [-V]
    	     Extra Options(psfxl only): -monotonic -x-duplicate
    	#Prints hierarchical tree (uses the low level srr hier tree)
    	srrutil -print-hier-tree -dbase <psfDir>  -dataset <dataset>
    	#Prints hierarchical tree (uses the srrDb tree (viva call))
    	srrutil -print-db-tree  -dbase <psfDir> [-o outfile]
    	#Prints dataset name list for a given database
    	srrutil -print-dataset-name -dbase <psfDir>
    	#Prints signal name list of a given data base (dataset is optional)
    	srrutil -print-signal-name -dbase <psfDir> [ -dataset <dataset> ] [-signal-type <typeName>] [-add-schematic-name]
    	#Prints signal list, grouped by type
    	srrutil -print-signal-type -dbase <psfDir> [ -dataset <dataset> ] [-print-signal]
    	#Prints signal type list (name, dataType, and number of instances
    	srrutil -print-signal-type-list -dbase <psfDir> [ -dataset <dataset> ]
    	#Prints dataset attributes
    	srrutil -print-dataset-attribute  -dbase <psfDir> [ -dataset <dataset> ]
    	#Prints datasets with contains a given  attribute
    	srrutil -print-dataset-attribute-value -name <attrName>  -dbase <psfDir> [ -dataset <dataset> ]
    	#Prints database attribute value (based on logFiles)
    	srrutil -print-database-attribute-value -dbase <dbase>  -key <attributeName>
    	Prints analysis information of a given database
    	srrutil -print-analysis-info -dbase <psfDir>
    	#Search signals on a given database
    	srrutil -search -dbase <psfDir>  [-dataset <dataset>] -mask <search mask>
    	srrutil -search -dbase <psfDir>  [-dataset <dataset>] -mask-file <file containing masks (1 perline)>
    	#Compute statistics on signal namespace
    	srrutil -signal-stat -dbase <psfDir>  -dataset <dataset>
    	Compute statistics on signal waveforms
    	srrutil -signal-wf-stat -dbase <psfDir> -dataset< dataset>
    	#Prints statistics on dataset
    	srrutil -print-stats -dbase <psfDir>
    	#Prints the current list of readers
    	srrutil -print-result-type-list
    	#Prints parametric (sweep) information on a given signal.
    	srrutil -print-param-properties -db <psfDir> -ds <dataset> -signal <signalName>
    	#Gets dataset information
    	srrutil -get-format-type -db <psfDir> -ds <datasetName>
    	srrutil -get-analysis-type -db <psfDir> -ds <datasetName>
    	#Secundary help pages
    	srrutil -h
    	   util           | extra        | amap        | cdnDebug
    	   logFile        | runObjFile   | stitchFile  | aliasTable
    	   compressString | compressData |             | ot
    	   sds            | psf          | spar        | fsdb      | noise
    	   compareDS
    GLOBAL FLAGS
    	-set-optimize-info-data      # internal SRR flag, used by DRL layer
    	-set-nb-print-sample <nb>    # max nb. of samples for printing WFs (5)
    	-hook                        # adds the malloc hook function.
    	-hookBreak <index>           # Stop code in a given index. To allow attaching the debugger.
    	-V                           # runs on verbose mode
    	-print-memory-usage          # Prints memory usage at the end
    	-strace                      # starts strace before opening dataset (for debug)
    	-nb-thread <value>           # Forces assync mode, on multi-thread (for debug)
    	-check-optical               # Sets the bit on SRR to read optical signals
    	-no-stitch-table             # Turns off stitch table
    	-simvision                   # Reads data on simivision mode client
    ENV VARIABLES
    VERSIONS
    	CDN Current build             : ICADVM20.1-64b.500.23 ICADVM20.1-64b 01/25/2022
