  3. how to check netlist when using LSCS mode
  • Views 10606
sjwprcker
sjwprcker over 4 years ago
I am running simulation in maestor with LSCS mode. My virtuoso version is IC618-64b.500.18.
When sim finishes, i try to use right click on the result to show the netlist, but the shown netlist is not complete. i guess this is from separate generation of netlist and simulation itself.
So is there any convenient way to check simulation netlist with LSCS?
BR
    That's the right way - I'm rather surprised that the netlist can be incomplete if the simulation finished - this is the netlist that the simulator will use.
    I assume it's not just because you see:
    include "netlist"
    in the netlist? Anyway, assuming it's truly incomplete, you should contact customer support. I cannot think of any good reason how this could happen (and the simulation be successful).
