  3. Multi-fingers in MOSFET in Series configuration in Cadence...
  • Subscribers 136
  • Views 15202
Multi-fingers in MOSFET in Series configuration in Cadence Virtuoso Schematic
Piash
Piash over 4 years ago
I am trying to figure out to set multi-fingers (nf = 3) for MOSFET (both p-mos & n-mos). I know I can increase the length directly. As connecting MOSFET in series increases length, can I somehow configure the finger properties (nf > 1) of MOSFET in such a way that S/D of each finger connects as series? I am asking to do it in schematic, not in layout yet.
I am using Cadence Virtuoso and 22nm technology.
    Andrew Beckett over 4 years ago in reply to Piash +1
    This will depend on the capabilities of the PDK - so is more of a question for the foundry. Andrew
  • JJJin
    JJJin over 4 years ago
    Open schematic, select the transistor, press Q , seek for number of gate fingers. Change it.
  • Piash
    Piash over 4 years ago in reply to JJJin
    Thanks for reply. I know that. My question was when I change number of fingers (nf) then by default the connection is parallel isn't it? Can I do the connection series when I change the number of fingers (without manually putting the number of separate transistors)?
  • Piash
    Piash over 4 years ago in reply to Andrew Beckett
    Thanks. I realized it is not possible for the pdk that I have. It is more conventional in layout...Anyway thanks
