  3. SystemVerilog generate loop does not compile modules defined...
  • Subscribers 136
  • Views 14499
SystemVerilog generate loop does not compile modules defined inside loop
Nader Fathy
Nader Fathy over 4 years ago
I am using Virtuoso IC6.1.8-64b.500.23, Spectre 21.1.0.303.isr5, and Xcelium 21.09-s005 with AMS simulator.
I have a SystemVerilog code that simply creates multiple sine waves as shown below:
module GET_SIGNALS
parameter ADD_OFFSET = 1,
parameter TIMESCALE_T = 1e-6,
parameter SIGNALS_COUNT = 16
// Inputs
clk,
rst,
A_bank,
f_bank,
p_bank,
A_offset_bank,
f_offset_bank,
p_offset_bank,
t_delay,
// Outputs
out
// Input ports definitions:
input clk;
input rst;
input real t_delay;
input real A_bank [SIGNALS_COUNT-1:0];
input real f_bank [SIGNALS_COUNT-1:0];
input real p_bank [SIGNALS_COUNT-1:0];
input real A_offset_bank [SIGNALS_COUNT-1:0];
input real f_offset_bank [SIGNALS_COUNT-1:0];
input real p_offset_bank [SIGNALS_COUNT-1:0];
// Output ports definitions:
// Output filtered data
output real out [SIGNALS_COUNT-1:0];
// Module Parameters & Variables:
real signal [SIGNALS_COUNT-1:0];
real offset [SIGNALS_COUNT-1:0];
// Call sine wave generator module:
genvar itr;
generate
for (itr=0; itr<SIGNALS_COUNT; itr=itr+1) begin
SINE #(.TIMESCALE_TB(TIMESCALE_T)) sin (.sampling_clock(clk),
.freq(f_bank[SIGNALS_COUNT-1-itr]),
.offset ($itor(0)),
.ampl(A_bank[SIGNALS_COUNT-1-itr]),
.phase(p_bank[SIGNALS_COUNT-1-itr]),
.t_delay(t_delay), .sine_output(signal[itr])
SINE #(.TIMESCALE_TB(TIMESCALE_T)) sin_o (.sampling_clock(clk),
.freq(f_offset_bank[SIGNALS_COUNT-1-itr]),
.offset ($itor(0)),
.ampl(A_offset_bank[SIGNALS_COUNT-1-itr]),
.phase(p_offset_bank[SIGNALS_COUNT-1-itr]),
.t_delay(t_delay),
.sine_output(offset[itr])
end
endgenerate
// Combinational Logic:
always @ (*) begin
// Initialize data
if (!rst)
begin
for (integer i=0; i<SIGNALS_COUNT; i=i+1)
begin
out[i] = 0;
end
end
else
begin
begin
out[i] = ADD_OFFSET? signal[i] + offset[i] : signal[i];
end
end
end
endmodule
This module calls another module called SINE, defined below:
import "DPI-C" pure function real sin (input real rTheta);
// Module Parameters & Definitions:
`define PI 3.14159265
module SINE
parameter TIMESCALE_TB = 1e-6
// Inputs
sampling_clock,
freq,
offset,
ampl,
phase,
t_delay,
// Outputs
sine_output
input sampling_clock;
input real freq;
input real offset;
input real ampl;
input real phase;
input real t_delay;
output real sine_output;
// Required variables:
// Sine wave time:
real time_s;
// Sine wave sampling clock:
reg sampling_clock = 1'b0;
// Main Module:
// Time scaling factor to convert actual simulator time into real time:
always @(posedge sampling_clock) begin
time_s <= $time*TIMESCALE_TB;
end
assign sine_output = offset + (ampl * sin((2*`PI*freq*(time_s-t_delay))+phase));
endmodule
Both modules are saved and compiled as SystemVerilog veiws in Cadence Virtuoso and symbols are instantiated in a schematic view. On simulating this in a test bench, I notice that the config view doesn't recognize the SINE module!
Hence, I get this error in xrun.log:
xmelab: *F,OSDINF (~/TDMA_uECoG_Project/GET_SIGNALS/systemVerilog/verilog.sv,83|49): instance 'TB_TDMA_uECoG.analog_module@TDMA_ANALOG_MODULE<module>.get_signals_module@GET_SIGNALS<module>.genblk1[0].sin' of design unit 'SINE' is a leaf instance and is unresolved in cellview 'TDMA_uECoG_Project.GET_SIGNALS:systemVerilog'. Ensure that the design unit is either pre-compiled or its corresponding text file is specified for compilation. Also, check the binding for this instance in Cadence Hierarchy Editor to confirm if it is set to externalHDL or addStopPoint or if nlAction is set to 'stop' for the specified instance.
If I unrolled the generate block loop manually (which is very painful!), the simulator runs fine. I tried to instantiate a dummy SINE block outside generate loop to make config view pick it up (which it did), but I got the same error.
Is there something I might be missing or is this a bug?
Kindest Regards,
Nader Fathy
    Andrew Beckett over 4 years ago +2
    It's not a bug but an expected limitation. The challenge is that the generate block is not unwrapped within the simulator until elaboration time, so it's hard for UNL to be able to see that there's a potential…
    It's not a bug but an expected limitation. The challenge is that the generate block is not unwrapped within the simulator until elaboration time, so it's hard for UNL to be able to see that there's a potential use of a module within the generate and that it needs to include the definition, because it's done before elaboration (and even if it was possible to elaborate the design, it wouldn't know that it needed to include the code to make the elaboration succeed - a kind of chicken-and-egg problem). I'm a bit surprised though that referencing it outside of the generate didn't solve the problem.
    Usually you just need to explicitly reference the SystemVerilog for the lower block (SINE) from the Simulation->Options->Verilog AMS (the include options on the Main tab).
    • Vote Up +2 Vote Down
  • SimbaG
    SimbaG over 4 years ago in reply to Andrew Beckett
    Thank you, Andrew, I have a similar question.
    If the instance is a Virtuoso Schematic, how to explicitly reference the files?
    Such as the following code, while "inv" is a Virtuoso Schematic.
    In the Cadence Training, "Behavioral Modeling with Verilog-AMS vXCELIUM 20.09", Lab 4, we use a Virtuoso Hierarchy Editor to specify which view will be used in the simulation. However, the generate blocks cannot be shown.
    Should we "package" the schematic in the genblock with an AMS code for using your trick?
    //Verilog-AMS HDL for "Training", "gentest" "verilogams"
    `include "constants.vams"
    `include "disciplines.vams"
    module gentest (
        input A,
        output Y
        electrical vdd,gnd, A, Y;
        electrical [3:0] mid;
        ground gnd;
        inv u1_inv ( .A(A), .Y(Y));
        genvar i;
        generate
            for(i=0 ; i<(4-1) ; i=i+1) begin
                inv u_inv ( .A(mid[i]), .Y(mid[i+1]));
            end
        endgenerate
        analog begin
            V(mid[0]) <+ 0;
        end
    endmodule
