  3. Sweep a device parameter during a transient using a voltage...
  • Views 11585
Sweep a device parameter during a transient using a voltage net
markris
markris over 4 years ago
Dear All,
That you know, is it possible in Spectre to set the value of an instance parameter (e.g. “W”) of a MOS using the voltage of a certain net during transient simulation?
I tried to create a verilog-a and verilog-ams model to sample the net voltage, store it in a file and read from it (on the fly) during the transient itself... but, as you may imagine, it did not work :(.
So, do you have any idea if this kind of simulation scenario can be handled somehow? Or I have no chance ? :)
Thanks a lot in advance!
    No, this is not possible. Andrew
  • markris
    markris over 4 years ago in reply to Andrew Beckett
    Ok, then fine... thanks a lot for the confirmation Andrew!
