  3. Custom vs PNR layout
  • Views 10743
StephanieIFX
StephanieIFX over 4 years ago
I am trying to generate a spef for custom layout.
For a layout generated from Innovus and imported into Virtuoso the cellview and instances have conns and terminal properties.  How can I get these same conns and terminal properties to be set for a custom layout generated from schematic?
    Not quite sure what you mean by "conns and terminal properties". If you're expecting the instances to have instTerms (in the database) with connections to nets, that's what Virtuoso Layout XL will do - not really sure what your issue here is though.
