  3. Describe the peak current method [Verilog-A]
  • Views 10904
YYLee
YYLee over 4 years ago
Hi all
I have a question about the current behavior.
How to describe the peak current?
For example, we have an inverter (A->Y); when the input value (A) rising to the Vth of the inverter, the nmos/pmos will be open. Consequently, a current suddenly flow to ground.
The solution i found is that:
-----code-----
integer peak_moment=0;
if(V(A) > Vth) peak_momnet=1;
if(peak_moment==1)begin
I(vdd) <+ 2.5uA;
peak_moment=0;
end
is it right? is it weird?
Furthermore, the peak current decided from the  circuit which peak in different moment and value.
So, is there have suitable way to describe the current peak in verilog-A logic ? really thank you!!
    ShawnLogan over 4 years ago
    Dear YYLee,
    I may not understand your question. However, if you are trying to determine the peak supply current for a conventional CMOS inverter, your comment "when the input value (A) rising to the Vth of the inverter, the nmos/pmos will be open" does sound quite accurate to me. As the input voltage to an inverter approaches its threshold voltage (the voltage threshold of the inverter - not the individual threshold voltages of the PMOS or NMOS device themselves), both the NMOS and PMOS device will conduct current and will not appear as "opens". The DC and transient responses are the supply currents are shown in the attached file.
    As a result, I apologize, but do not understand what the goal of your model is trying to provide. Sorry!
    Shawn
    ShawnLogan over 4 years ago in reply to ShawnLogan
    www.dropbox.com/.../inv_threshold_sim_supply_current_summary_041222v1p0.pdf
    Shawn
